supermaxx123
I was thinking of building a box for my sub to use in my living room, it's the 15 MKII.
I was going to go with 7cu/ft tuned to 24hz with 55"^2 of port area.
Would this work well?
It's mostly for music, movies maybe in the future.
here are the specs for the sub:
Parameters
Fs 26 Hz
Qms 5.5
Qes 0.51
Qts 0.47
Vas 113 liters
Znom 1 Ohm parallel
Re2 0.75 Ohms parallel
Le3 0.45 mH parallel
BL 15.9
Sd 749 cm2
Xmax 28mm one way linear
Pmax4 1600W RMS, 4800W peak
SPL5 87.6 dB @ 1W, 1m
Diameter 15.5"
Cutout 14"
Depth 8.25"
Volume 0.18 cubic feet
Parameters
Fs 26 Hz
Qms 5.5
Qes 0.51
Qts 0.47
Vas 113 liters
Znom 1 Ohm parallel
BL 15.9
Sd 749 cm2
Diameter 15.5"
Cutout 14"
Depth 8.25"
