Adding a second alt to my setup
  • 4
I have 2 extra alternators im planning to add one to my setup, just havent bolted it up yet. One is an 80 amp, externally regulated 3 wire like the stocker, other is a stock replacement, 80 amp internally regulated one wire setup. My question is, do i hook up the externally regulated ones regulator output to the same wires the other alts regulator is going to by adding in another plug or what? Or will i run into problems if i take the one wire alt and just wire it up in parallel with the existing one? //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
I would help but u thought i didnt know how to install deadener. so ill just keep my mouth shut
It is a little overkill with the batteries, but underkill with the alternator. Ideally, you want an alternator that will keep up with your system...
831
Thanks. That makes sense. It sounds pretty good as is.
I Like Waffle
North Carolina
I Like Waffle
