AD comp set already fcked up:(
audiobahnuser18
guy's please help me first day basically of having my comp set in and something already has went wrong:(. My right side speaker works great sounds great etc... the driver side door speaker is making some kind of rattling type sound with no sound output:(. i was listening to it just fine and then that just happened. what is wrong???//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif someone please help me
terminal or wire could of come loose and is rattling around
terminal still on there. but guy's was playing fine before . i took the good one on driver side put it to other channel on amp and works so nothing blown with the amp so that's a good thing:D.
Uploading video now. Don't mind the pic quality cause my camera not the best but u can hear the rattling type sound in the driver side speaker im talking about:(.
Video uploaded.
ngugraphics
hmm does it play but with the scratching sound? or is it just scratchy sounds?
RCA's maybe? try unhooking everything on that side and hookin it all back up.
you sure there are no wires touching any metal?
trey doesn't smell near the woofer at all. ska dude i don't believe so but i just found this out if i move my seat up and down where the amp is mounted will cut in and out. hmm.....maybe loose wire??? where do i start:(.
badd @ss chevy checked ground bolt alread it's tight as it's going. won't get any tighter.ground is tight fit doesn't move at all & i also sanded everything down.
audiobahnuser18
audiobahnuser18
Mi
customtronic
michigan born
    May 14, 2026
michigan born
    May 14, 2026
