Acoustic Elegance AV12-X D2!
microhaxo, hows the AV holding up after a few weeks of use? any differrence in performance? Do you think the AV could handle constant rap songs with lots and lots of bass? thx so much
Works just as good as the day i got it. I dont abuse the sub though and i know how to setup a system properly.
It handles constant rap songs every day from me.
Can't wait to get mine, will be picking it up from John in the next week or 2! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
John you should let me borrow 4 15 or 4 18s and I'll see how it stacks up against some of the best SPL subs. I live 10 minutes away from your shop. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i hope your not seriously trying to say that we didn't correctly install the woofer, if anything you have a fart box thats WAY to large.. so your claims and oponions are completely invalid...
for you other idiots kenny isn't comparing output, he is comparing frequency response...
I never claimed anything other than that i installed and used the sub properly.
Anyone who is looking to get this sub, all i can say is that it sounds great and you will be very happy.
This sub is a quality sub and should be treated as such. (not abused)
We are doing a direct swap out as soon as the 3" coil drivers are complete. This way we can test the apples to apples, as far as a sub made for getting loud and both having a 3" coil now. Hughes went up to the shop and checked it out as well. We may try to swap out his two 10"s I think it would be interesting to see a direct drop-in test in the street A application.
Hmm, sounds like john is pretty close to some 3" prototypes eh? lol
If he can get those up and running i think that would appeal to a lot of the SPL'RS around here.
that's what I like to hear. I'm very interested in these 3" coils but I'm only gonna have like 1200 RMS to work with.
the 2.5 will take that all day anyway. Judging by the heatsinking capabilities of his 2.5 you'd need 2000+watts to start to really push the 3inch coils, that's just a guess tho.
I think it's important to again emphasize the difference between thermal power handling and the amount of power it will take to get to the physical limits of the driver. Thermally the AV series 2.5" coil can take a large amount of power. When we hooked one up to the wall socket that gives about 4800W to the driver and the already damaged woofer still went for about 30sec with that kind of continuous power. Thermally 1200W or so as stated above is no issue for the AV woofers.
Mechanically it is a much different story. A modeling program can give you a fairly good indication of how much excursion you have in a given box with a given amount of power at each frequency. In a vented box it is especially important to have a subsonic filter to protect the driver from over excursion below tuning. Below the tuning frequency the port unloads and you are easily able to push the driver to high excursions. You are also doing so at frequencies that will be below the limits of audibility due to the rolloff. There really is no point to attempt to play these frequencies. A highpass filter (subsonic, infrasonic are the common names) protects the driver from over excursion and also gives back some headroom as the amplifier is not producing power for frequencies the woofer can't even play.
The ideal situation is to setup the system so that both the thermal and physical limits are reached approximately at the same time. That way neither of these factors are greatly limiting the output.
The 3" coil driver will be able to handle more power than the 2.5" coil thermally. It will also have more mass and more motor strength. As a result it will be more efficient than the 2.5" coil requiring less power for a given SPL while being able to take more power overall as well. The same things will apply in terms of mechanical limitations of the driver though as they apply to every/all drivers made.
John
microhaxo
microhaxo
MINNESOTA
microhaxo
