? about sound deadening
turboed331
i know the old saying "you get what you pay for" but im tryin to keep the price down as much as i can. there are a few companies on ebay that sell sound deadening material is any of it any good or will it work in any way. i see 50-100sqft rolls for $140 it must work somewhat right? and whats a good mil to get i also see 60mil and 80mil is the lower the # more thickness and higher is thinner? i just cant afford $300-$600 to do my car do you think this stuff will do? there is also 36sqft dnyamat for $89 all the shops i called in my area want $199-$299 for the same thing. let me know what ya think please. thanks
If your looking at fatmat on ebay I wouldn't recommend it. Its asphalt based, I've used it before in the past and its a pita and not the stickiest stuff.
http://www.raamaudio.com/cgi-bin/index.cgi?p=pr
Only heard good things about the bxt, good and cheap. I've run the dynamat extreme and its good stuff, but as you've found its hella pricey, especially local.
X2, and I think I saw someone selling some here in the last couple of days.
thanks guys. im stayin away from fatmat but the dynamat xtreme is pretty cheap for 36sqft. and these another company that used a 60mil and 100sqft for $140. whats the best MIL to get 60 or 80
How many sq feet do you think id need to do just the front doors?
what kind of car? i have a cavalier. i have so far only used 4 sq ft of dynamat extreme per door and now that i have a roll of raamat i plan to probably do like 20 sq ft total per door so it varies on how many layers you want and size of doors too
I just want to do one layer I guess
and I have an accord.
Think I could get away with just a small pack of it for like 50 bucks? Or would that not even make a difference if I did not do the back doors and trunk as well
cool good to know i figured to lower the thicker. whats a good mil to use?
Not sure there is a magic number. Thick is good, but it comes to a point where personally I wouldn't like it to be so thick it makes installation on uneven surfaces a *****. You can always do two layers if you want it thicker in areas.
All of the cheap eBay brands I've seen are asphalt - even the ones that claim to be butyl. Not worth using. Stick with the brands you've heard of - Dynamat Xtreme (watch out for Dynamat Original) RAAMmat, Second Skin, Cascade are all good enough. Second Skin and Cascade are deluxe.
If you have speakers in your doors, you want to do both surfaces - the inside surface of the exterior sheet metal and the interior surface that the trim panel mounts to. You also might want to close up the access holes.
To save money, don't apply it in even layers - concentrate on the centers of panels and areas away from bends and welds.
turboed331
turboed331
buffalo ny
Rudy
