a simple question from china
anl fuses are also called waffers they are usually of larger ratings like 60 amp on up to 300 amps..good for under the hood mostly and they typically cost 7-15 bucks...agu are your more common glass tube fuses rated 20 amps-80 amps (sorta like maxi fuses in rating) usually good for under hood of small systems (or smaller) and fuses for individual amps cost 80 cents to 3 bucks usually
They are different types of fuses.
Let's see if I'm not mistaken anl are the large plastic fuses sometimes called wafer fuses. They are usually for high power applications.
AGU fuses are the larger glass fuses normally found in most distribution blocks. They are the more common of the two types.
I would run a pair of 15s in an suv.. or run 4) 12s
24
I think it is the input sensetivity. Indicating you can wire direct ftom speakers.
21
I went with those simply because they fit, the cutout is round, and the hole will take a 6.5 coax. Cutting a square hole in a boat for a speaker...
21
5K
I think you're going to find this is true across the board. Technology has come so far at this point that even the absolute rock bottom unit that...
heathercable
heathercable
ningbo,China
ramos
    May 18, 2024
    May 18, 2024
