Bridge or not?
  • 3
the bridged output gets divided evenly among all subs - so yes 150 apiece. assuming that your subs are SVC 4 ohm... wiring them in parallel will yield a 2om load for your amp. MOST amps can NOT handle a 2ohm load bridged. check the amp specs before you bridge it.
3 ohms speakers are generally what some manufacturers do with factory systems, and wire the components in series. If your amp can do 2 ohm and 4...
5
If I didn't have my two 4500s already I would probably try the Creampie 7500/ Slapz 8k. :poop:
The question is confusing. Connect the 4" to the radio and use the rear amp channels for the sub. If the sub is DVC you can also use it in stereo...
BroMan
BroMan
East Haven, CT
imral3
DEW123
    May 7, 2024
DEW123
    May 7, 2024
Latest topics
