A little Soundsplinter and Fi sub comparison
JonJT
I've been doing a little research and modeling with Unibox so that I can decide which sub I want to purchase. I have compaired 6 different woofers in ported enclosures with varing numbers of woofers.
If I've made any mistakes in my calculations, please let me know! Thanks!
First, here is the box data for each alignment:
Next we have all the response graphs for each alignment
2x Soundsplinter RL-i10 d4
Frequency Response
Cone Excursion
Port Air Speed
Speaker Impedance
Soundsplinter RL-p12 d2
Frequency Response
Cone Excursion
Port Air Speed
Speaker Impedance
Soundsplinter RL-p15 d2
Frequency Response
Cone Excursion
Port Air Speed
Speaker Impedance
2x Fi Q10 d1
Frequency Response
Cone Excursion
Port Air Speed
Speaker Impedance
Fi Q12 d2
Frequency Response
Cone Excursion
Port Air Speed
Speaker Impedance
Fi Q15 d2
Frequency Response
Cone Excursion
Port Air Speed
Speaker Impedance
I'm really liking the combination of small size, small port area, short port length and high output of the dual Soundsplinter FL-i10 d4's. They are a little more costly than the other woofers, but I think I'll gladly pay more for the extra trunk space.
Hopefully this helps someone along with me!
JonJT
Obviously, but the fact that everyones car is different makes your point moot. I'm going to apply a transfer function to the SPL graphs for the 2 Soundsplinter 10s and see how it works out in my car only.
This is JUST a starting point for anyone who wants to use it. I never said I was posting EXACT response curves in car at all.
No, it makes my point all the more important. All those pretty graphs mean jack outside an anechoic chamber.
Good god. The transfer function that is specific to each car will not change no matter what alignment, sub or box you use. Its a scalar that is applied to whatever sub you decide to put in your car.
The anechoic response of any alignment is a good place to start looking for your perfect setup. Once you have them, you can apply said transfer function to your anechoic response and get a somewhat realistic frequency plot for your in car subwoofer.
NOT ONCE did I ever say these graphs were representative of how a sub would perform in car. EVER! These graphs are just a starting point from where a person can apply conditions specific to their application. Again, it is just a starting point comparing different subs.
Edit: This how I have been instructed to go about designing an alignment buy some people much smarter than myself. I am not providing a thread with the end results of any of these alignments in car.
true, if you actually know the basic transfer function of your vehicle you can plan around it.
I'd run a sim with the 15" RL-P & Q tuned to 32Hz. I've run them both at that tune and was very happy with SQ and output...
One of the reasons I ran the sim was to get an idea of how much space I'd need to get acceptable performance out of each woofer combination. The 15s require too much space. I need to keep as much space as possible because I'll be moving to and from college by myself. If I was confident a single RL-i10 would satisfy me, I'd go with that!
Once I get this transfer function going I'll have a much better idea of what I want/need.
here is a tip.
people in the high ups of competition use math and what not to make ideas on how to begin a box design. once they make it and test it, and sadly hit lower numbers than they had before, they start to modify or rebuild.
i dont know about you, but i know people who have built 20+ enclosures until they were happy. car audio is not all about doing all the math possible until it works, its also about trial and error, because all this crap is speaker\enclosure\car specific, and i dont think you will find many people using all 3 that are the same.
so just go build something that sounds promising, and then, build another one, and then try another one. its not like you will be able to tell with the first box if it boasts the best sound and performance unless you have a basis to compare it to.
so unless you build mutiple enclosures - you dont know what is the best with that speaker anyway.
thats just my 2 cents. i say build it, and it will come.
JonJT
JonJT
Jersey
JonJT
