Piston
*disclaimer* I understand Volfenhag and even Audiobahn are not high on the pecking order here.... but with that said I could use your opinions on what im about to put together.
I have (4) 15" Volfenhag DVC subs and a Audiobahn A2300HCT amp.
This amp, on paper, says it will do 2400w rms @ 1ohm, should be enough to push the 4 subs correct?
I have them wired in parallel through one VC of each sub which should give me the 1ohm load at the amp, I believe?
It sounds like the subs are under powered right now (actual sound in the van)
its in a 95 caravan with a wall, 1/0 stinger wire to the extra battery in the back. amp is wired with 4ga.
Each sub has 2.0cu/ft sealed.
Now before the flaming begins (just from reading the other threads of less than good equip), this is stuff I had laying around... im on a budget and will replace items as money allows, but this is what I have for the moment.
Thanks
Thanks
