bdonkersgoed
Hey Guys,
I am in the process of buying all of the gear for my new system, and was hoping you experts out thecould give me some setup suggestions. Here is the gear I am working with:
GEAR:
- Alpine CDA-9835 CD/MP3 Head Unit
- Focal Utopia 165W 6.5" 2-Way Components for the front (100W RMS each side, but not sure?)
- PPI Ax400 (Art Series) Old-School Amplifier to power the Focals
- Two Resonant Engineering RE8s to mount in the rear doors (175W RMS, DVC 4-ohms, but not sure?)
- Orion HCCA 225 G4 Old-School Amplifier to power the RE8s
OK, so that is the gear I am working with. Now the question is, how do I optimally set this system up?
Specs for Orion HCCA 225 G4:
2 x 25 @ 4 Ohm
2 x 50 @ 2 Ohm
2 x 100 @ 1 Ohm
2 x 200 @ .5 Ohm
1 x 100 @ 4 Ohm
1 x 200 @ 2 Ohm
1 x 400 @ 1 Ohm
Specs for PPI Ax400:
4 x 50 @ 4 Ohm
4 x 100 @ 2 Ohm
2 x 200 @ 4 Ohm
So, on to the questions:
QUESTION #1
My Utopia Components are bi-amplifier capable. The PPI Ax400 is a 4-Channel amp that can output 4 x 50 @ 4 Ohm, or 2 x 200 @ 4 ohms. Should I use all four channels and amplify each woofer and tweeter separately (50W to each), or should I bridge the amp and give 200W to each tweeter/woofer pair? Would 50W to each tweeter and each woofer be enough power for them?
QUESTION #2
What are the advantages of using biamplification for the Focal Utopias?
QUESTION #3
If I biamplify, could I use my Alpine CDA-9835's internal crossover to independantly control the tweeters and the woofers? The internal crossover has independant lines for "Front", "Rear", and "Subs". I was thinking maybe I could put the tweeters on the "Front" line, the woofers on the "Rear" line, and the RE8s on the "sub" line. Is this possible with my gear? Or would I have to have two separate amps powering each of the Focal Woofers and Focal Tweeters to accomplish this?
QUESTION #4
If what I suggest in Question #3 is possible, are there any realy good benefits to this setup? I think this way I can control the volume of the tweeters and woofers independantly (+/- db) ? Would this also allow me to send better and more appropriate signals to each speaker?
QUESTION #5
Does anyone know with certainty what the impedance of the RE8 is? Does anyone know any of the RE8s other specs? I hear that they are DVC 4-ohms . . . is this true? If so, then I would be able to wire the two RE8s in parallel to get a 1-ohm load, and thus get 1 x 400W out of the Orion HCCA 225 G4 amplifier that is going to power them . . .
So, that about sums up all of my difficult questions. I hope someone out there can help me out, because these questions are really bugging me . . .
I appreciate any help that anyone can offer!!
Thanks!
Bryan
GEAR:
2 x 25 @ 4 Ohm
2 x 50 @ 2 Ohm
2 x 100 @ 1 Ohm
2 x 200 @ .5 Ohm
1 x 100 @ 4 Ohm
1 x 200 @ 2 Ohm
1 x 400 @ 1 Ohm
4 x 50 @ 4 Ohm
4 x 100 @ 2 Ohm
2 x 200 @ 4 Ohm
QUESTION #1
QUESTION #2
QUESTION #3
QUESTION #4
QUESTION #5
Thanks!
Bryan
