A Few Questions On A Type R 12"
LoudSuperCrew
hi whats the best type of box for a type r 12" sealed or ported? also what is the recomed box voloume for this sub, and when im reading about a box and it says 1.5cft and the sub needs 1.5cft is that the right box for it because the sub takes up some of the room i dunno much about this stuff so any help would be great, also my amps 658rmsx1 at 2ohms and my type r is a dual 4ohm sub i think the only way i can wire it is down to 2ohms will 658rms blow it? my amps a alpine
MRD-M605 id like to wire the sub to 4ohms but ive been told i cant,also in the future if i buy another type r 12" giving each sub 330rms will they sub fine and work good? thanks.
i would recommend just sticking with one sub off of that power.
x2 unless you can throw 800w RMS to each Type R 12" meaning you'd need a 1600w RMs x 1 @ 1 ohm amp if you get the Dual 4 ohm if you get the dual 2 ohm you'll need an amp that will do 1600w RMS x 1 @ 2 ohms.
Don't go cheap on the power either....atleast buy a Hifonics BXI 16006D for $350
bxi1606d should be $250
bxi2006d is more like $350
that amp should be great for the sub. i'd recommend at least 2ft^3 after displacement tuned to 30-35Hz.
give us max height and width you have to work with and i (or someone else) can get a you a set of plans.
LoudSuperCrew
LoudSuperCrew
PortMcNeil,Bc
xluben
