Papermaker85
Banned
i will agree with RC with no clipping and less than 1%THD its very hard to tell the difference in a very high quatitly installaion.. if you by pass xovers etc... it can BE below the theshold of the human ear...
but in a real world installation, different amps clip differently.. some more rapid.. slew rate changes at different rates, dampning factor etc... some amps use 10%some 5% some 1% on the tolarences.. is it better? yes and no... yes because your product is much closer in every measureable catogory to one another(IE output,SN etc..) most installations aren't "ideal" and aren't set up with i Oscopes and bypassed crossover networks etc... this is WHY companies are able to claim and charge more.. some xover networks use 10% tolarences in there swiching supplies and crossover networks, while others use 1%... you might have a specific amp that has a A/N of 90db while another same board parts etc.. has 92db...
I am a firm believer in high quatily parts in amps, just like in woofers and anything for that matter.. under real world circumstances there is a difference.. now it was said eariler, if you use good quatitly amps properly tuned there won''t be a difference, as in you won't beable to identify class of amplification..
what DOES make a big different is how well the amp is when its out of its linear range this is where the larger power supplies, tighter tolerances in swiching supplies and x-overs etc.. come into play..
so if your going to get an amp a cheap amp chances are its not going to sound as good as a high quatitly amp, simply because your going to exceed its linear output.. on the other hand if you get a decent amp and properly tune it chance are you won't hear a difference..
