98 Stratus build
  • Thread starter Squatch
  • Replies 0
  • Views 609
Just installed my head unit today. It's an Alpine UTE52BT
Here's a pic after install, and may I say that I find it appealing.
This is the old head unit next to the new one.
I also ended up with some extras, and had to fabricate a ground since the stock ground strap was missing.
I'm sure you know what they are, but I will go over them anyhow., The black is the ground wire that found a nice home between two other grounding connectors, the pink and black is the Audio interrupt (dunno what it does, just know that it wasn't necessary for my car), and the blue/white wire is the remote. Some may ask why my remote line isn't running to the factory amp, and that is simply because I was instructed to use the power antenna connection instead.
It was a fairly simple process, and I fiinshed it in an hour. Next will be my first set of speakers and the battery relocation.
Squatch
Squatch
Northern Minnesota
Squatch
michigan born
    May 14, 2026
michigan born
    May 14, 2026
