nice to see some new pics, looks really good man
thanks, yea i guess its something hah
on a similar note, i have my system planned out. i figure i may aswell kinda keep this thread car audio related //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i will be running an active frontstage, and clearly the overall objective is mostly sq and a very clean natural sound. im jsut throwing some ideas around, im sure some of these will change
Source Unit: undecided. i want something that plays cds for when i want extreme sq hah and ipod control for daily and of course the long haul to california in the summer
Sound Proccesor: Audiocontrol EQL Dual 7-Band Trunk Mount Equalizer
Front Stage:
Mids - Dayton RS180-4 7" Reference Woofer 4 Ohm
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=295-374
tweeters - Morel MDT-29 1-1/8" Soft Dome Tweeter
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=277-010
Sub Stage
2x 8" ID8D2's wired to 2 ohm getting around 300 watts total
Amplifier
1 Zapco Reference 650.6 Amplifier
specs:
6-Channel amp with 3-Way Crossover, Band Pass, Bass Control and High-Current Sub Channels
-SymbiLink™ Balanced Input
-RCA Unbalanced Inputs
-2 ohm stereo stable, 1 ohm stereo on sub channel
-18 dB variable bass boost control
-3-way varrable electronic crossover
-Bridgeable
-Three to Six channel capable
-25-amp High Current Bi-Polar output devices
-Optically isolated MOSFET power supply
-Switch for use as stereo, single L ch. or R ch. bridge
-L+R sum mono for use as a bass amp
-Four layer PC board with heavy 2 oz copper
-Surface mount technology w/1% resistors,
precision caps, and massive ground planes
-High Current design allows maximum power at 2
ohm bridge on sub channels
Specifications:
Stereo, 4 ohms:6 x 50 Watts
Stereo, 2 ohms:6 x 90 Watts
Stereo, 2 ohms:Front and Rear / 4 x 90 Watts
Bridged, 2 ohms: 1 Sub x 325 Watts
T.H.D. + Noise:
S/N Ratio:>95dB
Slew Rate: >23V/uS
Damping Factor: >160 @ 4 ohms
Dimensions:31"L x7.5"W x 2"H
Suggested Retail $1220.00
Speaker wire/rcas : KnuKoncepts
