87 Safari- a little bass
yeah parkers are good, aka "barkers", they're pretty loud lol. what bags are you looking at getting? your gonna have a lotttta weight in there!
2600lb firestones all around, 1 10gal tank, and 2 Viar 480's- 8 parker 1/2in valves-
Im a dealer, so i can get em fairly priced //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
sweet! single bags in the back should be ok, def 2600lb bags. you probably wont get much lift tho lol. unless you put about 180psi in the rear bags lol.
bad pic, but this is my buddy Wes's truck. blow through with 4 MM3000.1's in the bed along with 4 Odyssey PC2150's across the notch. it took 150psi to get the ass end off the ground lol. he only had a single viair 380... it was a lonngggg wait to say the least lol
bad pic, but this is my buddy Wes's truck. blow through with 4 MM3000.1's in the bed along with 4 Odyssey PC2150's across the notch. it took 150psi to get the ass end off the ground lol. he only had a single viair 380 lol
You for got to add that he had 4 5200's in that bish too
sure did, i helped take them out when he traded the truck. dam them are some beasts.
btw, he broke off about 5 to 7 of the screws holding the subs in. they were literally about to fall out. i also snatched up his SAX100.4 before he left it in there before the trade //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif , got a really good deal on that.
here's a link to his vid on youtube:
that truck was a NASTY daily driver all-around.
Soo, its gonna take alot to get the rear up? most of the weight is in the middle, 175lbs in batts, 350lb wall w 200+lbs in subs
all of his subs were in the ex. cab part of the truck (so about 300+lbs plus the weight of the wall.) He went from about 60psi to get off the ground (bag on bar = takes a lil more psi) to 150+.
I'd say your definetely going to be giving you air ride a work out. you should be ok though if you go from the frame to the axle, or bag over leaf. i wouldnt recommend bag on bar. you dont want that much lift though, do you? maybe 4-5" right?
See what? I've had all this big boy stuff your talking about:laugh:
ROTFL, hush
No bag on bar, check!
So maybe i could get a 2700 in the rear, but it could **** on ride comfort?
Well, amps are back tommorrow, if i hvent sold em, ill get some vid os the van, with a little bass in it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
They should work. I have 6.5s in my lower door to replace the 8" subs that came with my mustang. They are fantastic, and outperform the 6 x 8s...
Well lets say I was running the tablet and 3 amps, would I use something more along the lines of a line output converter so that I would be able...
Those look like decent cheaper options for sure and probably fine for some systems, but I agree, Audiocontrol has been making high quality stuff...
288
Defiantly. LOL 😂 It has never happened to me👀:poop:
444
Maybe voltage loss? I always set my LFP to 80 and on steeper slope with no noticeable SPL loss. Playing a sine wave is a lot easier on your...
500
ascendantsubs1
IL
MikeyB
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
