8 gauge speaker wire issue!!!!
thats fine i was looking for suggestions. so i should solder it to the speaker cup??
so i dont mess up. all i need to dont is solder each tip to the corresponding male connector on the cup??
if you really think you need 8ga. inside the box you should just cut the terminal cup out, replace it with a piece of wood and do direct-connect wiring from the inside of the box to the outside (and seal around the hole for the wire). I found using 8Ga speaker wire a pain inside and outside of boxes, really not worth it
I use 8 gauge speaker wiring. And its not an over kill. These eletrical-buffs contridict them selves continously. Increasing the size does help. Here are the differnces in speakerwires for a setup @2000 watts, 5 feet of wire, with 1 ohm.
16 gauge wire:
1820 watts getting to the subs
amps: 42
Voltage drop: 2.06
14 gauge wire:
1884 watts
amps: 43
Voltage drop: 1.32
12 gauge wire:
1926 Watts
amps: 44
Voltage drop: 0.84
10 gauge wire:
1952 watts
amps: 44
Voltage drop: 0.53
8 gauge wire:
1970.19
amps: 44
Voltage drop: 0.33
...So, the differnce in upgrading from 12 gauge to 8 gauge is youll get 44 watts more of your amp and youll gain over half a volt point. Definetly wont be audible or an EXTREME difference...but it does help to have a higher voltage; and we car audio-enthusiast could all use a little extra help with keeping our voltage high //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
16 gauge wire:
amps: 42
Voltage drop: 2.06
14 gauge wire:
1884 watts
amps: 43
Voltage drop: 1.32
12 gauge wire:
1926 Watts
amps: 44
Voltage drop: 0.84
10 gauge wire:
1952 watts
amps: 44
Voltage drop: 0.53
8 gauge wire:
1970.19
amps: 44
Voltage drop: 0.33
sweet this guys smart!!!//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
16 gauge wire:
amps: 42
Voltage drop: 2.06
14 gauge wire:
1884 watts
amps: 43
Voltage drop: 1.32
12 gauge wire:
1926 Watts
amps: 44
Voltage drop: 0.84
10 gauge wire:
1952 watts
amps: 44
Voltage drop: 0.53
8 gauge wire:
1970.19
amps: 44
Voltage drop: 0.33
Thank you, 8 ga. is only overkill if you don't need it!! LOL
HOLY JESUS 44 WATTS. you wouldn't be able to tell the difference if $1 million depended on it.
Maybe not, But i bet you could tell the differnce in a 0.51 voltage drop. Thats the differnce in 10.50 volts and 9.99 volts. or 11v and 10.49v.... Yah.
taysextreme
Want some Come get some
taysextreme
jersey
Foote
