6x9 Recommendations
The reason I didn’t go with the X series and went with the V was because the former doesn’t have a tweeter adjustment in the passive crossover. My tweeters are mounted on the upper part of the door near the sail panels so I prefer a -3DB option since they are closer to my ears, than the mids. If you’re active, you don’t have more options
I installed a 5-band eq in my kid's truck and the silk domes were pretty smooth. Therefore, the DB switch wasn't really needed. However, the 6x9's had the switch on the crossover.
"X" series is adjustable-
As are the "V" series-
And if you're active, you are using an electronic/active crossover on the amp or DSP/EQ/Crossover and will have much greater control versus passive.
oops typo supposed to say does not don't
I was going off the photo of the passive in the gallery there is no switch but the manual illustration shows differently.
HinkDawg
CarAudio.com Recruit
HinkDawg
Ohio
2RZ-FE
vegang
vegang
