!5" sub options?
Mr.meyhem
Looking for a 15" sub that will handle over 1000 rms. my box that i have built is tuned to 34 hertz. and is about 2.9 cubes/ (ported) Im running an apsm 1300 for an amp right now but might upgrade to and mb quart 1500. My obsidian that i have right now is starting to smell when i try to run more power through it. so just looking for possible upgrade options.
Also, any opinions on a good amp to match sub suggestions. thanks
gbob2003 built the box for me. thats rele the biggest i could fit in my trunk.
---------- Post added at 09:20 AM ---------- Previous post was at 09:19 AM ----------
pm me some pics of the skar
we have the sub facing up and the port facing forward. thats the only way to fit a 15. i think i only have like 18" for height in my trunk.
what r the specs on the sa 12 d2?
yeah i got a newer civic. and i just got all this set up not even in the car yet but we tested it in gbob2003's car and it was loud but started to smell. every things pretty much new so i could prbly get back what i bought it for. but I'm more trying to figure out a different system for down the road. thinking two 12's idk what amp. id have to put in a high performance alternator or another battery if i went to two 12's right?
Any suggestions?
241
383
491
In that airspace you could go ported with th Si SQL 12@$369, hands down the best option in a 1.41 ported box. With 1000 watts RMS and 92 db...
16
811
526
Mr.meyhem
Mr.meyhem
Cold as F***, MN
Mr.meyhem
    May 16, 2024
    May 16, 2024
