.5 ohm vs 2 amps stapped @ final 2 ohm load(each amp @ 1ohm)
  • 7
bgowdy
Heroes are remembered, but legends never die
I was just curious how this works toward a electrical system. i know it can vary due to the many factors. i looked through search and found the info on those factors. but nothing on this. so really the only thing im wondering is which would have the bigger draw on electrical system?
This may be a dumb question but its something that im curious about.
thanks in advance,
//content.invisioncic.com/y282845/emoticons/toast.gif.bc0657bf54b9ee653b6438524461341e.gif cheers
Run higher ohms if you can.
why would i want to run higher ohms? im about to recone my sub to a d1 regardless because my amp is .5ohm stable. running higher would defeat the purpose of me having the 3.4k amp.
not trying to argue or be smart with you by the way
Exactly. The higher impedance you run, the cooler and more efficient your system runs. And that makes your equipment last longer.
this is true. but honestly i dont run my system hard at all daily(about 1/4 or 1/2 power tops even for a demo). comps i run full tilt for about 1min 25secs tops
if you get two 1500 wattt amps and strap them you can run 3k at 2 ohms
this is know. thats what i meant in the first post. stap to amps to 2 ohm(1ohm each). and the question being which would be less strain on elec. .5ohm or 2 amps strapped to 2 ohm.
the reason i was confused was i know .5ohm is harder on elec, and strapped to 2 ohm is a higher imp, but with 2 amps
Ouch, you are right! So I won't burn anything? This is great news!
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
195
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
850
bgowdy
bgowdy
Campbellsville, Ky
bgowdy
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
