5 Channel
corbett123
Okay i figured out all the speakers i am going to run. and i was just wanted to see if the amp i picked out is good for the speakers that i will be running.
For the dash 3.5" BA s35
Front doors PG RSD 5.25"
Rear Deck Alpine Spr-69c 6x9 and PG RSD 5.25"
Also my subs are 2 10" p3
and i was thinking of using the ed nine.5 to power everything
can i get some feedback?
thanks
NINe.5 sounds perfect. (hopefully you have the electrical for one)
/thread //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
will i be able to run that off my battery or will have to do something to run it?
Run at least 4 gauge wire to the amp.
If the lights dim on high volume play still, look in the sticky or search for "big three", do that.
(may want to do this anyway)
If the lights dim on high volume play still, look at a kinetiks 1800 batt.
http://www.sonicelectronix.com/item_7342_Kinetik+HC+1800.html
If the lights dim on high volume play still, you may need a new alternator.
Your speaker choices sound fine, you may want to run the 6x9's and 3.5's
off of the head unit and run the ED to just the RSD's and subs.
The P3's are nice, but you may want to start a Subwoofer suggestion thread;
there are lots better.
corbett123
corbett123
Flemington, NJ
mcsoul
