5 channel amp vs multiple amps?
rugbeanz
so im installing 4 speakers and 2 subs in my car.
what are some pros and cons of a 5 channel amp to power all of them or a mono amp for the subs and a 4 channel amp for the speakers.
2x 6.5" @ 50 RMS 4 OHMS
2x 6x9" @ 60 RMS 4 OHMS
2x 12" kickers 150 RMS 4 OHMS
My suggestion is Massive Audio nx3 it's a 3 ch amp the sub ch alone puts out 800 rms which can be split to run two subs. I have this amp and brand new shipped to my door it was 150 bucks.
Running multiple amps depends upon your budget too if you have one.
Run a 5 channel
I love mine
The only reason to get a mono after a 5 channel is if you want more power
And even then you still have a 5 channel to use as a 4 channel!
i would only opt for the the 2 amp setup if you ever plan on upgrading by getting amps with a little more headroom on the wattage. However that's obviously gonna be more expensive than the 5 channel option. However if you're gonna stick with what you have than 5 channel is a very solid look
speaking of multi amps what about the shaker 1000 in a mustang it runs Four 4ohm mono amps for two 10" dual 4ohm subs, one amp per coil. what do you guys think of running the four amps in parallel or in series to power one sub? is that even posible? what would the ohms be? and could it power a dual 2 ohm sub that ive got laying around? dual 2ohms can be wired to 1ohm or 4ohm i think. i know this is a bit off topick but im new here and i couldnt figure out how to start a new thread:emb:
10
456
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
668
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
I would keep the amp you have and keep the components. Place the components in some universal door pods, and look at getting a powered SAS 8"...
13
A 6 channel and a single sub amp would be my choice. Or a 2ch, 4ch and a sub amp. You don't need 2 channels for subs.
933
rugbeanz
rugbeanz
Minnesota
Boomin_tahoe
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
