5 channel amp help
Ag248
hey guys i just bought a 5 channel crunch power one amp and i hooked it up in my truck with one 12" pioneer shallow mount and two 6x9s.. the problem is the 6x9s only played bass and were all distored. i tried messing with all the settings on the amp the distortion went away but the speakers made no sound. idk if i have it wired wrong or what. i ended up just taking the amp out and putting my old 2000w bamf in for my sub. any help would be great i just want to know how i can hook up those extra speakers. thanks
shows your headunit has front and rear/sub pre-amp outs. chances are you used the rear/sub pre-amp out and didn't change the setting on the headunit to send a full signal. if that isn't it I really couldn't tell you without more info.
i think i know what ur talkin about. on the headunit settings it says subwoofer 1 and subwoofer 2. and if u click on that it goes down to like 60khz and up to 180khz. is that what ur talking about? if so what should they be set at? because physically there is only one set of rca coming out of the back of the headunit. thanks again
Ag248
Ag248
Sarasota,fl
vaiboy
