4th Order Design
cyn
Okay who wants to design a 4th order for me.. would like to have the design by friday..
1 Sub = Re Audio 12" HC 03 model
1 Amp = AQ1200.1 wired at 1ohm
car: 07 Imapla LT - seats don't fold down
space to use: 36W x 14D x 16H
Want a lot of air movement... but I want it to be non-peaky
its easy, do a 2:1 ratio which means for every 1 cubic foor sealed you would do 2 ported then tune the ported section to 40-50 hz
for your sub i would do 1 cube sealed 2 cubes ported at 45 hz, use re box calculator to make the ported section or the12volt.com
also bandpass designs have a pretty wide band width
---------- Post added at 12:28 AM ---------- Previous post was at 12:28 AM ----------
tune it to 42 for a lower response and more air movement //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Ummm... I would never use RE Calculator... and there is a lot more into designing a 4th than a 2 to 1 ratio...
I know how to use Bass Box Pro and WinISD... just would like someone that does this all the time and can get more detailed in the design than I can with everything else
Why not hit up one of the box designers on the forum. Not every sub will perform well in a 4th order. The Fs looks fine, but the qts is rather low for a 4th order. That sub will probably perform better in a ported or 6th order.
Well Buck was designing the box for me till he got sick... and most everyone else usually takes a week or more to do a design
From my understanding, drivers that work well in 4th orders have a lower Fs (which your sub has) as well as a qts of .5 or higher. I would maybe ask for a 6th order design, or just go with a regular ported.
As stated above .50 or higher for qts. You can also use the drivers EBP, which is Fs/Qes. I believe if EBP is less than 70 go 4th order and greater than 70 go 6th order, but not positive on that.
cyn
cyn
Orange, Texas
cyn
vegang
vegang
