4th order bandpass enclosure help
Audiopipe
I'm trying to design a 4th order bandpass box for two audiopipe 15s but don't know which air space to use the subs I have call for 3cube ft each in a sealed box and 3.5 cubic ft each in a ported box. I have heard people say 2:1 ratio but is it off of total of 13 cubic ft or the seals or ported . I guess what I am asking is what cubic ft should I use for each sub sealed and what total cubic ft for the ported section and what size should the port be for say 32hz please help!!!
if its for spl you dont need that much in the sealed area if you plan on giving it a lot of power than recommended probably around 2.25 to 2.5 should be fine, leave more room for the ported section.
from what I've seen, 4th's don't model well on winISD for example, when using a bigger ported chamber to sealed chamber ratio. They become too peaky.
i'd suggest sticking with ported or buy a design off of a professional on this site @Buck ; can design you a box that'll get ultra loud.
you dont want to just guestimate with 4th orders you have to make sure a lot of variables are correct first.
from what I've seen' date=' 4th's don't model well on winISD for example, when using a bigger ported chamber to sealed chamber ratio. They become too peaky.[/quote']
they dont model well but they do turn out pretty flat in response with a decent bandwidth based on your tuning. It also really depends on how compatable the box works with your vehicle.
It's actually going in a trunk of a Benz but has a custom fiberglass rear deck with a big blow threw
even if the trunk is really big, 2 15s 4th order in a trunk is kind of stretching it, unless you build it inside the trunk and take out the spare tire compartment. I wish you the best of luck though.
the 2:1 is a solid choice and gives you a pretty good handling and bandwidth. the 2.5 : 1 has the potential to be a lot more peaky depending on the tuning.
If you're going for SPL in a 4th order you don't want tuning that low. In the low to mid 40s would be better for both your goals and your subs, as they will not play well at low frequencies without a shite tone af air behind them.
If you want to do it right, I would recommend downloading WinISD Beta and modeling the subs in a number of different boxes. If you can find a curve you like on that program, then build it.
But just trying different volumes at random or relying on rules of thumb ratios that do not take into account the characteristics of the individual drivers is the reason why 4th and 6th order enclosures have the reputation of being hard to design.
is this a ported enclosure or a 4th order? If 4th and tuned to 33hz, unless specifically designed to do that, it wont have any bandwidth. It might...
I’m going to stick with the 4th order bandpass for now and see if it can improve it. The bandpass actually plays 100 rebased songs good.
I hope you didn’t misInterpret my last message.. I was excited that I actually understand what you’re talking about… Lol! I will level with you. I...
14
Audiopipe
Audiopipe
Spring hill fl
RangerDangerV2
    Jun 1, 2024
    May 31, 2024
