I too have a design for 2 bandpassed 15's in a trunk. It will not be a blow through however. Each sub will also get its own box due to a small trunk opening.even if the trunk is really big, 2 15s 4th order in a trunk is kind of stretching it, unless you build it inside the trunk and take out the spare tire compartment. I wish you the best of luck though. the 2:1 is a solid choice and gives you a pretty good handling and bandwidth. the 2.5 : 1 has the potential to be a lot more peaky depending on the tuning.
My setup will be 1.52cuf ported and 1.7cuf sealed after all displacements. 65hz tuning. It was modeled with my cars resonance frequency and cabin gain in mind. Can't wait to build it! wooooo hoooooo!
