Sold $450 max for a system?
anyone have a nice system just sub and amp for $450 at the most or cheaper? post it up here or message me, it might take till sunday for me to write back
define system? do you need everything (headunit, speakers, subwoofer, amp, wiring) or are you looking for specific items or what?
//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
op: check the classifieds thers aton of nice gear in there.
reading > me i guess //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
get two of these:
http://www.sonicelectronix.com/item_3408_Kicker+05CVR102.html
one of these:
http://www.sonicelectronix.com/item_9552_Hifonics+TXi+1508D.html
One of these:
http://www.knukonceptz.com/productDetail.cfm?prodID=KLM-K4
That comes out to about $425
then, build yourself a box using this tutorial:
http://www.caraudio.com/forum/showthread.php?t=215849
You cant go wrong with kicker CVR's on a budget system. Kicker made so many of them, they are easy to find for killer prices. Hifonics is always a decent budget amplifier. They do a little less power than rated in many cases, but definately still worth the power for the $$$. Build yourself a box and you'll get great output.
Those 10" CVR's would do wonders in a 4cu ft box tuned to somewhere around 32-35hz
I have a Diamond Audio D5 1200.1 with a Diamond audio D9 10"d2 for $500 + shipping. unless you wanna pick it up. Its a sick system make your car sound nice.
I have a Fusion NV Series 15" Sub, a Fusion Powerplant 2000 watt Amp , and a
15" ported speaker box that I am selling...
I want $450 for everything plus shipping. Make offer.
I paid $700 for everything. Still have my receipt. Still have all original boxes.
Ive just had them sitting in my closet.
I bought this system for my IS300. The speakerbox will not fit into my trunk.
It was only used in my truck for a month. Less than 30 hours of play.
Im getting sponsored for SEMA with my is300 so I decided to sale the equiptment.
In case you arent familiar with Fusion. PAS magazine did a write up/test report a sub and amp of theirs in the Dec 2007 issue.
Ill post some pics by this weekend. Or you can email me at ehende22@aol.com.. or PM me if interested.
Sub:
Power Rating: 2500 Watts (Max)
Voice Coil: 3" TIL Dual Voice Coil
Impedance: Dual 2 Ohm
Magnet Structure: 308 oz Triple Stacked
Amp:
Monoblock Power Plant Series Amplifier
Superior Thermal Conductivity : PowerPlant amplifiers feature superior thermal conductivity ensuring heat dissipates efficiently
Rugged Amplifier Case : Single piece extrusion with seamlessly matched die-cast end caps which protects connectors and internal components
Over-sized Mounting Feet : The oversized mounting feet with their recessed holes provide secure and discreet fastening points.
Over-Sized Power Connection : Enlarged contact surfaces for high current connectivity
Stage 2 System Management Panel : Multi-function management panel enables you to refine the characteristics of the signal to suit your audio preferences.
Multiple Fuse Protection : Multiple fuses protect internal components and are easily accessible for quick changes in a competitive environment
465 Watts RMS x 1 Channel @ 4 Ohms and 1% THD+N
750 Watts RMS x 1 Channel @ 2 Ohms and 1% THD+N
1150 Watts RMS x 1 Channel @ 1 Ohms and 1% THD+N
Linked Power Ratings @14.4VDC
1000 Watts RMS x 1 Channel @ 4 Ohms and 1% THD+N
1800 Watts RMS x 1 Channel @ 2 Ohms and 1% THD+N
Max Power Rating: 2000 Watts
Max Current: 100A
Full Rated Power Distortion (Max) 1kHz: 0.45%
THD @ Rated Power 1kHz/100Hz: 0.3%
Frequency Response Hz (-3dB): 10Hz - 250Hz
Signal to Noise: >90
Variable Low Pass Filter: 12 dB/Octave
Bass Boost @ 45Hz: 12dB
Input Sensitivity: 0.2 - 8V
Input Impedance: 47K
Fuse Rating: 25A x 4
FergieFurg
FergieFurg
Boston
richierich75
