4 way crossover
  • 6
may I ask what would you need a 4 way xover for?
so i can have total controle
the set up is in a 95 maxima i have a soundsteam sme 808 in each door with the front door have in a power acoustik nx5
and the rear deck i have 4 neo pro 10 sundown with a pair of nx5 an 2 selenium st400
on 2 power bass asa 600.4....
my plan is to
2 ch on the 4 soundstream
2 ch on the 4 sundown (low mids)
2 ch on the 2 selenium (mids)
2 ch on the 4 power acoustik (hi)
or u think its a bad idea???
thinking of 2 good 12 off a american bass 500.1 have amp already no sub or even 2 15 if i can build a box inside the trunk
also with the controle / crossover i can blance it how i want... i love clean loude mids
12db is usually 180° out of phase if used left and right. 24db makes the full 360° phase change when running left and right. This is...
362
On another note, if you're competing in SPL, you might want to check around at what the best crossover point is. These two drivers (your 6.5s and...
I usually cross at 80hz And as a drummer The meaty end of a kick is 40hz..like bands such as Metallica 50hz is a U2 kick
mr.tigger
mr.tigger
Brooklyn, NY
garychoffmann
    May 20, 2024
    May 20, 2024
