4" budget speaker recomendation
Hi, speakers are for a 95 toyota avalon with an aftermarket headunit and stock oem amp. my door speakers are distorted. was wondering what you guys would get for around $20 - $40 a pair.
thank you
Like um some bazooka, JVC, Pioneer, Sony... for that price range... really need a little bit more cash per pair for something worth a **** though..
Stay away from crap like Pyle, Legacy, Boss...
Here are a few suggestions based solely on the price.. LOL
Clarion
Walmart.com: Clarion SRG1021R G Series Coaxial Speaker System (4"/140W Max): Auto Electronics
Another Cheaper Clarion:
(22.95) CLARION SRG1020R
4" 2-Way 140W GOOD Series SPEAKERS
BLAUPUNKT- Used to be pretty decent for entry level.. dont know about now..
(24.95) BLAUPUNKT GTx-402 (GTx402)
4" 2-Way 130W GT Series SPEAKERS
Kenwood-
(39.95) KENWOOD KFC-1062S (KFC1062S)
4" 3-Way 120W SPEAKERS
Anyways.. there are tons of decent entry level speakers from good name brand compaines out there.. just look around.. hell or go to Walmart, or Car toys or w/e or shop online.. there are tons.. stick with name brands.. dont go with the cheap'o name brands.. either..
Are you looking for coaxials, or full range speakers? Is your price before or after shipping? If you can bump up the price to ~$60, I have a plethora of suggestions for you. If you're 100% stuck at ~$40 before shipping, there are plenty of nice options as well.
Don't listen to this guy, things like this are what tools say.
i'm just looking for the best bang for your buck speakers. i'm willing to go up to $60 before shipping. could you link me to a few options?
thanks
Dayton RS100-4 I have a set of these as desktop speakers paired with a small subwoofer and they are fantastic.
Tang Band W3-1364SA An amazing set of full range speakers. They're 3" so you'll need to make a bracket to make them fit correctly, but they are simply awesome. I have them running from 350hz and up in my dash location in my car, and I love them.
Fountek FR88EX Like the 1364sa's, an awesome full range speaker. A bit brighter due to the metal cone, but they also have a greater xmax, so they have greater output capabilities.
Tang Band W4-1052SD Nice 4" full range speakers that will be able to dig a little deeper than the 3" full range drivers at the expense of some top end. Still a great speaker that I wouldn't hesitate to run in a car environment.
The only downside to these full range speakers is that they will need some eq work and need to be installed on-axis to get the most out them. That doesn't mean they won't sound good off axis, but it's the top end that will suffer the most should you install them off axis. A nice aftermarket amplifier to give them some power wouldn't hurt, either, especially since you could use the crossover on the amp to block out the lower frequencies. But it's definitely not a necessity if you're just doing a drop in replacement.
Just to clarify, where will the speakers be installed? In the door by your feet? Or in the middle of the door? Either way, as drop in replacements, any of these speakers would be a great choice. If possible though, I'd build a crossover to block lower frequencies (a high pass of 80hz - 100hz would suffice) so that way, you can get a bit more out of the speakers. This is assuming you have a subwoofer to pick up the lower frequencies.
the speakers are on the door at the bottom. if you had to choose, one out of those 4 selections. what would you take? i will be doing a drop in replacement.
thanks for quick responses
I'd go with the dayton's simply becuase I know what they sound like and I'm already impressed by them. But I 've been wanting to try those W4's...
You can also look into those Kickers Dpc mentioned. They might fit the bill even better since they're going into the door by your feet. Coaxial speakers would probably be a better drop in choice. Here's the KS400's, a bit more pricey but look to be a bit better; make sure to check ebay if there are better prices.
there's a button to the bottom left of my post for that:thumbsup:
bigd87
bigd87
bolsa, ca
Side Show
BP1Fanatic
BP1Fanatic
