4 MT 15s
not much to loom at but heres a little update
dont mind the wonderful walmart battery they are getting replaced in a few days when my others show up. of course wont bump till they are in. i will not **** up a $3300 amp
all wiring has been upgraded to 1/0 of course
the alt is a Excessive Amperage 300 amp
subs are supposed to be delivered tomorrow then i can finish that d**n box and will be running my power wire tomorrow.
more updates and pics to come over the next couple days
well huge change of plans. if anyone has seen my thread over in classifieds im gettin screwed on the subs i bought.
was supposed to be 4 15" MTs
were reconded as 18s
they havent been delivered and the seller wont take my calls or make contact in anyway with me
Cadence came thro for me again tho
all Cadence set up
will be 4 Daytona RVC 15s now
going to work on the box today. had to scrap a full sheet of 3/4 MDF that was doubled up since i already cut holes for the 18s
thanks to the seller for costing me so much on this project now
will post pics this evening
working on bracing, new top, and hopefully cover the SOB
the material i got to cover it needs to get out of the house before it gets screwed up. NOT CARPET
Those dowels aren't really going to do much //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
But looks good overall //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
they are really only there to supprt the weight. they are 1 1/2 inches dia.
the box is 2 inches thick on all sides
the reason i used the dowels in the box rather than using mdf or something else simply they let air flow around them freely.
thanks for the compliment. i just hope i can get it together and the material on it tonight. we will probably run the wiring as well. using pvc inside the frame rail to keep it from getting hung up or something. afterall it is a 4x4 and i do use it like a truck
this isnt car audio but with all that weight i had to put an air suspension in the rear. too the better part of yesterday
i didnt go all out for the compressor and everything cause i dont need it. if i need air i can get out and put it in
the bags will support an extra 2500lbs
HUGE DIFFERENCE already
i can't believe you drilled a hole in the bumper. looks gay. sorry //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
people around here drill the license plate hole a little bigger and use it through one of the plate holes. really clean, you can't even tell its there.
Anything else to hate on with his build?
Dowels will help if they're tying 2 sides together same as threaded rod. I've built several boxes like that and they never flexed and the dowels stayed in place.
Spot in the bumper looks functional to me and works for you, so it's all good...
he wanted opinions...mine is looks gay. is it functional...sure. personally i don't like the location. whatever, it ain't my truck. besides, he knows i'm f*ckin w/ him. i hope to make it to the comp on sun.....and i'll show yo @ss up //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
**** right you will
NO SUBS HERE YET
ill do a good 50db off my door speakers to 50 NOT150
bones22
bones22
in my house
PSturmer
