4 4" Aeros?
would the port displacement for one 4" aero that is 20.5" long be .149 i was wondering if my math was right and another thing do i add that to my box and then do it again to figure out how long they need to be.idk im kinda confused my box is. 4.59 with sub displacement and i want 4 4" aeros tuned to 38 any help
if you already made your box then you need to:
-figure out the port length
-figure out the port displacement
-subtract the displacement from the box's original voulme
-re-calculate the port length using this new volume
--if using the precision ports, subtract 5" from this number and cut your center tube to this length
if your using more than one port, divide the box by the numbers of ports and use this number to figure out the length. cut each port to this size. (this can be done for doing the calculation to find the first port length from the above steps.)
i just try to get the most i can in there with staying under 18''s long overall. my current spl build will have 4 4'' aeros and 4 12's, these will be very short, like 10 overall but space is very very limited. and another build i am doing 4 15's and 5 6'' aeros (on this build they come out to 18'' long)
bopo668
JerryRig
bopo668
tex
PSturmer
