4 guage fuse
What is the max size fuse to use for the big 3 using 4 guage? the alt is 100a.
125A for 4ga.
Also if youre runnin a comp amp and sub amp, would it b better to do 1 run to the back or 2 separate runs? the sub run would b 1/0 and the comp will b 4 guage.
Depends on what you want to do. Do you want a dedicated run to each amp, or do only one run to save money?
I would do 2 separate runs, 1/0 & 4ga. Use a 300A fuse for the 1/0, and 125a for the 4ga.
for 4 guage, use a 150 amp fuse
and i have a setup like your looking to do, and what i personally did was run 2 runs of 1/0 wire. (1 positive, 1 negative) ran them to 2 distribution blocks that sent out 1/0 wire to my sub amp and 4 guage wire to my comp amp. so you could also use d-blocks to your advantage, but keep in mind that using them could end up being more expensive then another run of wire and fuse holder. its all your preference
125A for 4ga.
well i already got the 4 gauge run thru the car from my previous setup. i was just gon run the 0 gauge a long side of that so each amp had its own power wire, and gettin some 4 gauge for a friend to do the big 3.
But then i thought about takin out the 4 guage and using that as the wire for my big 3, then ran the 0 guage to a block then to the amps.
i got a 250a fuse from knukonceptz wehn i brought my 1/0 amp kit
Lets Get It
Lets Get It
Where im at
Lets Get It
Mike Mccabe
