setting gains?
▼)Ñ╩fZΣµ&
well on my kicker 750.1 running at 2 ohms, i reset my HU and put volume to 48/62
then on a clean song pretty much turned it on let it play
then started to turn up the gain till about half way and it sounded 100% fine
shouldn't the gain mostly be lower than 1/2? i havnt bolted the subs into the box yet( t test if i had right wiring and everything worked etc..), and just about at 1/2 they started to jump up, so i backed it down ha
but in general shouldn't gains be not higher than 1/2?
There's a lot more to do with it than that it shouldn't usually be more than 1/2 way up.
well i have 2 subs that do a total of 800rms,, the amp is a kicker 750.1 and its running 2 ohms
about half its hitting pretty hard for the volume level, and 0 bass on the headunit or amp with volume 48/62 i cant really hear the clipping if any... would it be bad for the amp to just run it a bit low? or not
it goes to 11 so half is like 5.5 and i have it set to like 4 area
also what should a good area for frequency really be? its around 80 atm
▼)Ñ╩fZΣµ&
▼)Ñ╩fZΣµ&
reno
▼)Ñ╩fZΣµ&
Mike Mccabe
