4 DP21 Wall Build
Does anyone thing it would be a bad to mount the subs with either 2.5" or 3.5" deck screws until I can get nuts and bolts to bolt them in?
I actually got some 1/4" x 2" Lag screws for my Warden, they are great and obviously being that big, you need to pre-drill correctly. You can get a bigger one but you gotta make sure the head of the bolt wont come in contact with the surround if you do that.
Maybe Ill go that route...With the subs being mounted upright instead of laying down, I wanna make sure that they're in there good lol.
love the build...getting the itch again to get back into caraudio after 3 years w00t
Thanks
all i can say is WOW ! I've been fighting with my 4 12's and what to do with them and then run across this . Makes me want to get a cap for s10 and cut the back wall out instead of fighting with extended cab areas .
Thanks...You could do a 4th order blow through, or a 6th if you really wanna make some noise.
LULs you should throw small children in the port when you want to change tuning
Haha
rmzsuzuki89
rmzsuzuki89
St. Pete, FL
boomzabit
AJ (ACE)
    Jun 24, 2026
AJ (ACE)
    Jun 24, 2026
