4 Ch 6000 watt amp to 2 1400Watt DVC 15" subs how should i wire speakers to amp
kyle1153084
I have a 4 ch 6000 watt amp (pyle PLA4988) its brigeable 4 Ohms : 2 x 3000 watt or 4 x 1500 watt
it is 2 ohm stable and i wont to hook it to Two 15" 1400 watt DVC 4 Ohms per coil (plye PL1590BL) subs i wont to know the best way to wire them up should i run the coils in series or parallel.
lulz //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
If the amp does 1,500 watts x4 @ 2 ohms (lulz again), just wire the subs like this
Use channels 1 and 2, one sub per channel. That'll allow you to save the other 3,000 watts of power for future upgrades (more lulz).
In reality, there's no way in hell that amp is doing anywhere near 1,500 watts per channel. NO WAY!
If its rated peak to peak it can //content.invisioncic.com/y282845/emoticons/rotflol.gif.b453361716769b8110ddefc85ff03cd2.gif:rotflol:
BRAND NEW Pyle PLA4988 4 Channel 6000 Watts Bridgeable Mosfet Amplifier
RMS Power @ 4 Ohms: 4x200 W
RMS Power @ 2 Ohms: 4x320 W
Bridgeable RMS Power @ 4 Ohms: 2 X 3000 W
Maximum Power Output 4 X1500W
4 Channel Bridgeable MOSFET Amplifier
Frequency Response 20 Hz-50kHz (±3dB)
Output Power @ 14.4v DC, 50Hz
2 Ohm Stable
MOSFET Power Supply
PWM (Pulse-Width-Modulation) System
Glass Epoxy PCB
Silver RCA Inputs
Custom Terminal Block For Speaker Connection
Thermal / Overload / Short Circuit Protection
Input Impedance: 47K Ohms
Soft Turn On/ Off
Advanced Protection Circuitry
S/N Ratio: >90dB
Dimensions: 9.76'' W X 2.99'' H X 16.93'' L
To the bolded.... Math fail?
It's a 400w amp at the most. The amp is junk. The subs are junk. That amp wouldn't put out 6000w if you could measure the heat dissipation after you set it on fire.
It still amazes me how people in this day and age of the internet still go blow money on junk and don't take the time or effort to do a little researching.
All it takes is one friend who says "yo dawg that pyle is so good bro it slams the hell out of my explodes!"
He wants to strap the amps to double the output to one sub. Some amps allow you to "couple" them. This allows you to wire up the one sub powered...
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
Thanks man I’ll give it a try I’m usually pretty bad at this kind of stuff. I wasn’t sure if there was a website or something that had a picture I...
If I didn't have my two 4500s already I would probably try the Creampie 7500/ Slapz 8k. :poop:
kyle1153084
kyle1153084
foster, mo
whitedragon551
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
