4 AQ HDC3 10's in cut-through
Thanks a lot man... I'm sure hoping for the best in my town //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Well got most of the wire needed to get this project rolling... all I need to do is build the box and order the subs. I got some Knukoncetps Kolossus 1/0 wire, some flex-a-prene 4/0 welding wire from my friend at airgas, and a buddy gave me some infinty kappa perfect 6.5's so I instaled those all in about a half hour so i could at least have some tunes... I been so busy workin in my friends car doin a semi-wall that I haven't hardly had any time to work on the truck.
Heres pics of my stuff
Heres what my friends car looks like... Nice simple and clean
Thats pretty sweet. I like that you deleted the rear seat completely.
I love the older fords, I grew up in an 88 F250 my dad had and then my first truck was an 83 F250 and I would most certainly not even hesitate to buy it back if I had the chance, same as you put plenty of money into fixing it up. I would never guess that truck to have that much motor in it, specially with the factory steelies on it. Love the truck and love the build should be loud for sure //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
These will actually hit harder than my 2 15's... I like hard hitting bass that on ocassion can get low... the 2 15's would only sound alright on low tone songs and when I would just listen to a full CD it was just way too sloppy for my likings... These will be a tad louder and cleaner but not a tremendous amount and not nothing that will probably show on a meter possibly .2 if even... This is just so I can listen to a variety of music daily and still be able to pound the lows when needed... But it will be unbearable loud around 38-40hz and still musical into the low 30's
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
961
If I was in your situation, I would experiment with the wring for a day or two. If that didn't work, I would purchase an external amplifier. Run...
Yeah well im a maintenance technician working 12 hr days 6 days a wk ontop of school 3 times a wk which are 4 hrs long .so ya an hr drive is hard...
Hello there people! Ive recently purchased a car and it came with a sony xav ax headset. It could be an ax3000 or ax3200. Im wanting to upgrade...
TnT_Sounds
profiling gets **** done!
TnT_Sounds
Colorado
bunkerking09
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
