4-6k, maybe a bit more, .5 stable
any proof that these are .5stabele
Originally posted by Team Livewire - Eric:[QB] Ok guys, here it is. Depending on your battery set up this amp will make an ungodly amount of power. With a 12volt battery set up dropping to 11.5 volts the Crunch GP3000D Pro made 2850 watts at a 1.03 ohm reactive. That's 4 12volt batteries. If you can get the voltage up the amp will make much more. By just starting the car and using the high amp alternator (starting at 16.1 volts and dropping to 12.3volts), the 3000 made 3732 watts. That's crazy isn't it. THAT'S NOTHING! I hooked it up to a 16volt battery set up and it just went crazy! With the battery voltage dropping to 15.7 volts with a 1.4 ohm reactive this monster made 4640 usable watts. NOW WHAT DO YOU THINK ABOUT THAT! [/QB]
1.03 ohm reactive........gotta be most likely under .5 nominal wiring
and will **** a gagillion amps of current //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
they will also run
x263643737
The MA Audio SX line is their high current line. So yeah.
i have a 300A alt and 8 kinetik 2400s that can be ran at 16v, so i should have enough battery power. i may look into those as a cheap option. but im highly considering these GP3000Ds. i know who wagonized is now.
i remember those being for sale also.i might be going with the GPs, save some money.
.5 stable and can be ran at 16v.
pioneerpimp
pioneerpimp
IL
pioneerpimp
NorthFramingham
    Jun 30, 2026
