nope, i'm building the box and tc sounds is building the speakers. as unbelievable as that is lolPlease don't tell me james is building this or building you subs.
man, for a box housing 2 ridiculous 18" woofs i'd put a brace every 15" at least on the large, flat panels, even if it's just a piece of 1x2.nope, i'm building the box and tc sounds is building the speakers. as unbelievable as that is lol
as for bracing, i've got top to bottom bracing between the speakers and 2x2's under the first baffle on the port for top to bottom bracing. also braced back to front by the port obviously, and braced in the middle from port to side on each side. where should i put more bracing?
note that this is not a competition build, so i'm not trying to squeeze an extra .4dbs out of this system. just a daily driver:suave:
Its 4 18s... Lol.man, for a box housing 2 ridiculous 18" woofs i'd put a brace every 15" at least on the large, flat panels, even if it's just a piece of 1x2.
James Pantazes(Rip) not F. James F is cool, he has my old 4500's and wmd2 motors.**** those revos were sick! those should be sweet.
and i believe they are being made in san diego, i dont think the factories in china can make the 5200 tops since they've been discontinued for 3 or 4 years
which james were you talking about btw? rip james or james fahey?
each side holds 2, and in theory the center divider should have equal pressure on both sides.....however, you're correct lolIts 4 18s... Lol.
Im too tired to figure out what you just said there, but if that pic shows your final bracing, you need more. You need, at the least, some bracing between the outer wall and the port wall. Id even consider a brace between the port walls, inside the port. A window frame brace job would be best though. Maybe its just the pic, but that looks like a very tall box with a lot of wall area that is not braced.as for bracing, i've got top to bottom bracing between the speakers and 2x2's under the first baffle on the port for top to bottom bracing. also braced back to front by the port obviously, and braced in the middle from port to side on each side. where should i put more bracing?
