4 10" Type R's
i built a box for 2 12" type r's in a 06 4 runner 1.50cu@38hz each chamber running off 2 v12 605 on each sub and it was crazy, so 4 will probably be insane! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif loud without a doubt
one of those amps isnt enough power for 4 10s if theyre the 2005 Rs.. its a waste of money on your part to have 4 subs if you only have enough power for maybe 2.
what were you using to power the t1? same amp? if so then yeah 4 10s or 2 12s would prolly be a little louder just based on cone area.. but if it IS the same amp and you do want it quite a bit louder then id suggest another hifonics and then get your 4 10s or 2 12s. if set up properly that would probably inflict a little pain.
well i now there are other factors such as amt of pwoer and such, i was just saying the vast difference..
sorry im' not a ca.com god or anything
You cant just add up ithe cone diameters like that because it isnt correct.
Find the area of each round woofer and add it up, that will be a number to work with...
Fred P
Fred P
Elk grove
Fred P
BP1Fanatic
BP1Fanatic
