3 subs and a 2ohm load?
  • 2
phoneman
i like pie
3,887
ok
would 2 dvc subs and 1 svc sub wired in a 2 ohm load work,
would there not be any kind of negative affect due to mixing dvc and svc subs?
I am wanting to wire three kappa perfects in a 2 ohm load.
what does anybody think?
dont mix subs ..they are different and react different and if not the same ohmage...... the higher impedance sub will rule......and if they react different then you will have phase shifts out the yin yang............... 3 dvc 6 ohm coils will give you 4 or 1 ohm........... but 2 ohms is hard to get with what you want to do....4 subs would work though wire 2 4 ohm vc dvc's in par.....then each pair of parralle wired subs.wire them in series with the other pair......
98
16
417
559
phoneman
i like pie
phoneman
ok
audiolife
    May 18, 2024
    May 16, 2024
