3 ohm speakers....
you're measuring DC Resistance, not Impedance. Impedance varies with frequency and is affected by the free air resonance and inductance of the voice coil. DC resistance has many factors that influence it's measurement, even your DMM leads and the quality of your DMM. A $200 Fluke will me more accurate than a $20 Radio Shack model. Accuracy costs money. You're also measuring the resistance in the wire and connections you made to wire the coils in series.
example of an Ultra Subs LV10 4 ohm sub:
Thanks. That is what I figured but I wasnt sure if there was a chance for the amp to see the lower load ever and put it into protect
Very possibly. "Rise" is only valid if you only play a known frequency test tone. Your amp may "see" that 1.5ohm often. SO the answer is really it depends on the amp how forgiving it is. Many woofers that are labeled "4 ohm" by the manufacturer do have DCR of 3 and change....also some 3 ohm woofers actually have DCR of very close to 3.
Slayerx
Slayerx
Sacramento
Slayerx
vegang
vegang
