3 8ohm SVC sub wiring
ya well i figured out that if i just do 4 8ohms and wire 2 pairs in series thats 16 and then wire those 2 in parallel its 4 but i think that might be wrong but thats what 12volts calculator gave me.
If you do your initial plan, the subs are not all going to see equal power. Avoid that.
Wiring a pair of 8 ohm subs in series gives you 16 ohms. Wiring two pairs of those together will drop the impedance in half to 8 ohms.
Just wire it down to 2.66, then run each channel of the amp that you're wanting to bridge to the subs(ie: don't bridge the amp, just run each individual channel to the subs so that each channel sees the 2.66ohms).
That's the best I can think of for you to get the most power with what you have.
These two equations are all you need:
http://en.wikipedia.org/wiki/Series_and_parallel_circuits
scottyfkachris
scottyfkachris
Port Orchard, WA
smoka
