3.5 @ 35htz Design Help
RedDiamond
Would anyone be able to help me with this design? It's for a single 15". I need it 3.5 @ 35htz, and no more than 19" in depth. All the designs I have found, have either been taken down, or are poorly made. If anyone could help me, that would be great, thanks.
You shouldn't be planning on running a 15 tuned to 35hz if you don't have about 9 cube gross to work with. It's too small for a 15" and too small to tune that low with adequate port area without taking up a lot of volume.
I'm going by what is reccomended for the sub.
9 cubes?!
It's a single 15...
op is talking about net vol im assuming.
In 3.5 net I'd be on the fence between 10 and 12" In testing in 3.5 cube I meter higher with a 10 in the same box (same motor, softparts)..... of course excursion becomes a problem outside of tuning so I'd possibly do a 12 depending how much power was on tap.
we do 53's on music with 3.5 per chamber with many different types of 15s here in MN in a little red ranger.. 3.5 IMO is optimal for most 15s.
we do 53's on music with 3.5 per chamber with many different types of 15s here in MN in a little red ranger.. 3.5 IMO is optimal for most 15s.3
I'm sure that same vehicle would do the same numbers with 12's in the same box then. Smaller box = less output and steeper peak. 3.5 is generally MINIMUM for most 15's and IMO most manufacturers only just say that because people have their heart set on big subs to impress their buddies and won't know any better when the see the "recommended" specs. Kicker "recommends" 6 cube for solo X 18. Give that a whirl and let me know how that plays out.
RedDiamond
RedDiamond
Pinedale, WY
n8skow
NorthFramingham
    Jun 30, 2026
