3/4 inch drill chuck???
So will using the Hole Saw break my drill or something? Or is it just big *** drill bits?
Hole saws are made for wood not metal... It can be used if you plan to use one or two times.
If you dont have a torque drill then you will end up jamming it and smoking the motor.
Any reason you can use one of these?
Shop DEWALT 3/4-in Black Oxide Twist Drill Bit at Lowes.com
That drill bit should be big enough and fit in a normal drill and yes this can be used in metal and wood.
I forgot i need it to be 14 inches long lol.... Unless I can find an extension... I saw some at HD earlier idk if that will go in though but it might. That thing will go through sheet metal and wood?
why does it have to be 14" long thats crazy? and yes you can get metal hole saw bits, i have plenty.
Based
Based
Louisiana
Slo_Ride
