2ohm front and rear
I plan on upgrading the speakers in my accord with some DD stuff i have, I want to use a C3b i have and run each channel at 2ohms (L for fronts R for rears) any issues with running this set up
Amp: DD-C3b Cont Power at 2 ohm 300W x 2ch
Front: DD-CS 6.5 RMS Power handling 160W per CH
Rear: DD-AW6.5 Power Handling 120W RMS
Should be fine then. If you don't already have those mids I wouldn't buy them simply because rear fill really isn't that important and those mids (assuming I'm thinking of the right ones) aren't on the cheap side.
you're losing your left/right balance???
you're doing it wrong. combine front left and rear left on one channel, and front right and rear right on the other channel.
you want to maintain your balance and lose your fader.
Do you like to rock out to AM talk radio? Your 'stereo' will not have 'stereo' if you wire things that way unless you have a barber's chair for a driver's seat and drive while looking over your left shoulder. It'll probably sound terrible and you'll get a sore neck. Not good...
bad03ranger
Get Some *****
bad03ranger
Reidsville, North Carolina, United States
BnGRacing
