$2500 to spend help me out
Seriously though, I would advise you to factor in wiring too. Maybe cut out the crossover and use that for wiring for your big 3 and power to the amps. Someone mentioned an H.O. alt. I would do that as well.
Lay the proper groundwork first and rework your budget.
The 2500 is ONLY for EQUIPMENT i know i still have more to spend on wiring /alt. etc.
Alright so im trying to stay under 2600.00 for all the equipment for a system for my truck please let me know if iam setting myself up for failure
Vehicle 2006 GMC 2500 Crewcab
3 maybe 4 10" re se subs $ 80 a piece $320.00
Sub amp Hifonics 2608D $400.00
JL zr 800 8" in front doors $125 a piece $250.00
PG RSD 65 one set in front doors with the JLs $90.00
PG RSD 65 other set in rear doors maybe no rear fill?? $90.00
Mid/highs amp hifonics 8408 or arc audio 300.4 $200.00 0r 400.00
MA audio 3 way crossover $70.00
Kenwood DNX 8120 $1200.00
Total $2620.00 or $2820.00
Guys please chime and let me know what you would change or if you think the setup would sound good. I really want a good sounding setup that is loud and good spl while still having some SQ
Having done the 4 re 10 in the same vehicle i can tell you it wasnt impressive, the re8 that were in before sounded better and performed better as well. However the three might work???
So you are telling me that a re 8" will sound better than a re se 10" thats hae dto believe but okay and 3 would be better than 4 ? because of air space acoustics im confused what do you have now if you didnt like the re se
Save it you will need it when 3/4 of the country is unemployed;)
id have to agree with him.... all my stuff in my truck i have traded out work for i havent spent a dime on audio in like a year ...... save it if anything give urself a lower budget and put some in the bank u can have a pretty nice daily setup for under a grand
How bout a Stetsom 2kd(400)
And a stetsom TH2120(115)
A pair of PG RSD comps(70)
Deka 9A31 (200)
And 4 RE SE 10's(320)
That comes out to $1105.
Plus your $1200 HU and your under 2500.
killintime
killintime
houston
dtbrown
