$25 to the person who can design the best system for under $500.
Speakers: I'd keep the bose, bose speakers are nice and probably wouldnt be much of an upgrade. Although I have the cdt cl61s and they sound nice...but my dad has bose speakers in his infiniti and they sound just as good...
Speaker Amp: I'd power them with a kicker kx150.4 amp 160$ at thezeb.com
Subs: 1 12" Resonant Engineering REs .. 90$ or so ... that will deliver some nice sounding bass, RE is a great brand.
Sub Amp - Hifonics Merlin 150$ from thezeb.com
Wiring: like someone said knukoncepts.com prolly 50$ or so
I dont plan on winning or anything, just trying to throw ideas at you, but I must say it was painful looking through the brands (besides RE and kicker) trying to find something suitable. You have to keep in mind that a lot of brands that willb e mentioned like profile, legacy, hifonics are not top of the line stuff, and if you save up a little more money you will only be buying once, versus spending 500$ on decent stuff and buying again later.
You dont need to buy a whole system at one time, buy speakers and a speaker amp now, and in a couple months get a sub and sub amp. No rush.
good luck!
1) David Navone 4-channel LOC - $35
-Hands down one of the best line-out convertors on the market.
2) Comps: OZ Audio Vector Components - $115 shipped via member tplaya07
-nsgm13 said he hasn't been able to find a set that beats his CDT's because he hasn't heard these Vectors //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Here is a quote from a very knowledgeable individual who is well respected on a different forum and who's very familiar with the Vector's as well as higher priced speakers when I asked a question about budget comp sets:
....If he doesn't have a lot of cash, I STRONGLY suggest the Vectorcomponents...they blew me away for the price.
3) Comp Amp: Clarion APX201 - $68
-Great budget amp. IMHO much better quality amplifer that has a higher quality company standing behind their products.
4) Sub: Adire Audio Tempest - $150 shipped
-Very affordable and well performing sub. Proof? Quite simply read the forum....one of the best performing subs for under $300; and there are some who actually preferred this sub over their JL Audio W7 (currently the "benchmark sub" supposedly)
5) Sub amp: Clarion APX401.2 - $110
-Same as comp amp description
6) KnuKoncpetz Wires - Very affordable and high quality wires
Then with our assistance build your own ported box //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
4) Sub: Adire Audio Tempest - $150 shipped-Very affordable and well performing sub. Proof? Quite simply read the forum....one of the best performing subs for under $300; and there are some who actually preferred this sub over their JL Audio W7 (currently the "benchmark sub" supposedly)
Are you sure that these two will pair well? The Tempest has dual 8ohm coils, so you can only achieve a 4ohm, 8ohm, or 16ohm load. The Clarion sends 280W at 4ohms mono (if I’ve read the specs correctly… they’re a bit hard to find), while the sub is rated 750W for both coils.
If I don’t have something grievously wrong up there, I would recommend the Hifonics Zeus ZX4000 instead, which sends 400W @ 4ohms. A second can be used as a component amp, as well, if aesthetics is a concern.
1st, the amp is rated 380w @ 4ohm bridged. 2nd, that 750w is THERMAL ONLY. Tempest only need 400-500w ported to perform to their maximum. And for all intents and purposes there is no difference between 380w & 400w.....
I read that it was 380W @ 2ohms. And I never suggested that a Tempest required 750W, only that 280W fell well short of its capability.
• Maximum Power Output 400W • Continuous Average Power Output 200W (100W x 2 into 4 Ohms 20Hz-20kHz @0.05% THD)
• Typical 2-Ohm Stereo 190W x 2 @ 0.5% THD
• Typical 2 Ohm Mono Power 1kHz 380W @ 0.5% THD
they all have amps on them already. bose is a good stock speaker but cant compare to the sound of aftermarket speakers in my opinion.
Oh, the amps are attached to the individual speakers? I assumed that they were not, and that replacing any part of a Bose setup required replacing all of it (minus the head unit).
Nope, that amp is not 2ohm mono stable. That is 380w @ 4ohm mono.
I'm pretty sure that it is. Here's a features list from Sounddomain.
# Customizable Heatsinks and Heatsink Vents# Built-In Variable Low-Pass and High-Pass Crossover
# Selectable 12 or 24 dB / Octave Crossover Slope
# Crossover Frequency Multiplier
# Stereo, Mono, or Summed (L + R) Mono Input Selector
# Line or Speaker Level Inputs
# 2 Ohms Stereo / 2 Ohms Mono Stable
# Gold-Plated Input and Output Terminals
# Bass Extender Boost Control
# Differential Input Stage with Ground Loop Isolation Circuit
# Double-Sided Circuit Board with PWR Power Supply
quixotiK
quixotiK
kentucky
uncleroman
