Sold 2400 @ 1ohm amp f/s
Bobby322
I've got an alphasonik pma1200da. Does 2400 @ 1ohm I believe it does rated or close to it. However, it does have a problem. Something is burt with my power supply in it and it doesn't put out as much power as it used to. It still turns on and works though. Some amp repair guys said its not an expensive repair. I can post pics and more info when I get on my computer (typing on phone) later. EDIT - it acutally has started putting out more power since I plugged in the bass knob lol, but still has a problem.
Pictures are a few posts down..
$175
The amp test was bs in the first place. Ive heard of guys with xplod shit getting benched at the place coming back with "near rated" results. Thats not the problem. It smoked like a chimney from the get go. I have a feeling you sent me a screwed up amp from the begining. I should have know by the way it was so ****ing beat up and so cheap.
edit - hooking up an amp with just power and ground in and it smoked. not a faulty on my part.
you said it was just the battery ground under your hood in your for sale post
Thought it only smoked cause of something with a ground. I had my back battery grounded seperately, then I grounded it with a wire from the front battery. Dunno what the deal was. Basically its about the broken warrenty seal. I wouldn't have bought it if I knew the warrenty was void and u told me it had 18months
Ok well if you think so why didnt you get in touch with me this was a very dumb *** thing to do. I didnt screw you over. If i thought the seal was broken I would have not said it had a warranty. And if it malfunctioned right away then well common sense should have told you something and called me but since you didnt and I thin k since you didnt i thin kyou are lying about many things as any intelligent person who knows anything about audio would have not kept using it. If it smoked why didnt you say so instead of saying it worked when you hooked it up hell you could have at least mentioned it smoked but worked fine but no mention of this magic smoke. Me thinks the smoke was between your ears my friend. And in your vid it didnt look like 12v. I didnt even want to sell you the amp as you we're acting very strange askin me where i worked and odd stuff, but hey i said whatever and went ahead now wish i had kept it and had it working in my car still.
I just can't get over why you did not mention anything to me at freakin all I had to find this in the classifieds to find there was a problem wowsa.....
But yea im about done with all this since obviously like many said im not at fault. And especially for your ignorance //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif. hope ups can maybe help out or you can get it fixed and have a nice amp
Bobby322
Bobby322
TX
basebalz13
