SOLD 240 1/0 Ring Terms, 7-Way active crossover, Indash Voltmeter and Wire/Acc
j3bus2k3
Si vis pacem, para bellum
6,712
St. Pete, FL
Ok, I've been long out of car audio but this **** didnt sell at a swap meet and needs to go...
-First off, "uncommon" indash tsunami voltmeter. gives xx.x readout of voltage as well as fuse status for up to 4 fuses. Fuse indicators are blue IIRC, and readout is red. $50
-Second, is another uncommon or rare item; a Coustic XM7 7-Way active crossover. Adjustable gain, freq and Q for front and rear. High pass, band-pass mid and band-pass low with independant level control for High Mid and Low. Badass little unit. Never used it myself, good condition. $100
-Third, 240 1/0 ring terminals and 94 4awg terminals. Bout awhile back and was using them for my projects and customers, but I'm out of the game and these are useless. ALL SOLD
-Remainder of JL Audio Wiring Kit. 14' Red 2Awg Primary, 3' 4Awg Ground, 17' Monster 2-Ch RCA, 13' Remote and an extra 1' 1/0 battery ground. $60.
Also pictured is an 18' stinger 4-ch RCA. $10 extra or seperate, NOT included with JL kit.
Random Crap:
-Inline Knuconkeptz 1/0 fuseblock with 250A Fuse SOLD
-Box wiring terminals; accept up to 12awg wire. $2 (Free by choice if you purchase something esle)
-12" Subwoofer Rubber Gasket/Rings SOLD (Free by choice if you purchase something else)
-Knukonceptz Ground Distribution block. I never installed it but it is used. SOLD
-Speaker Rubber gasketing. Used for behind the basket to seal against the wood. $2 (or again, free by choice if you purchase something else)
Want this stuff gone. Prices are negotiable but I'm not even gonna reply to ludicrous offers. Thanks Guys
hrtbrk1 and JBL Camry, your packages went out. Should have been emailed the shipping information to whatever email you use for paypal.
BUMP
The 240 should be 2x40/ 2ch. rated at 11.9v. Should generate close to 50+ @14v rms. Only Rated @4 ohms bridged Mono.. Should be around 125 rms...
Had a set of Ecplise 6x9's back in the day in my '99 Grand Cherokee. The SE8495s iirc those were so sweet sounding. Wish I hadn't sold the GC with...
I have never heard SP Audio. From what I have sampled, it seemed that the DB Arnolds sounded the most detailed. Then again, they were auditioned...
That's subjective. Personally, I find the hot/shrill sound produced by the comb filtering to be unbearable, so I wouldn't even listen to the...
20
j3bus2k3
j3bus2k3
St. Pete, FL
j3bus2k3
    May 24, 2024
    May 23, 2024
