2017 F-150 Crewcab options
Is there any foam under the carpet that might compress with the seat down?.. I was told it fit well... it was 11" in front, 8" in back 56" wide...
I raked the baffle slightly so it would fit under the seat lip better... magnet clears and it goes low and loud according to him... he had a CAB at 1/2 ohm on it so I ported it for +2000 watts
With 2” lift I can do the 11” front, 8” back, I don’t mind the 56” it’ll stick out a inch on each end.
I would suggest you do yourself a favor and buy the kit. It's not just square tubing or a straight up lift like suggested. I asked him to post pictures of it finished and he never did I like to see what he came up with. Here's a picture of the front mount for the lift kit and a picture of the box I did with a lift I used sa-8 v3s.http://i1259.photobucket.com/albums/ii542/inteva61841/20171231_124158_zpskkqbraxg.jpg
http://i1259.photobucket.com/albums/ii542/inteva61841/20171231_124209_zpsqeb61xcc.jpg
Check inbox
Ok cuz the video by Lmi welding rear lift kit is on YouTube installing it.
Yeah its a really easy kit to install. I like mine I would absolutely spend the money to buy the kit again.
Ah, I weld so I can get it done I mean the bottom pieces easy as hell to get. The rear upper hook with spring not too bad. I saw 2 z shaped brackets but video didn’t show where it go, what’s up with the z brackets?
Thats the picture in the link I sent you. Its the front mount. None of its crazy difficult to do it just wasn't worth it to me to spend the time figuring it out.
Ah I gotcha. So you went with the Sa8’s? Never heard of 8’s well the bs kicker factory 8” on 200 watt amp in the truck now. Been around 12’s n 15’s my whole life. Heard 10’s once or twice not bad.
Yeah the forum talked me into them. I had never heard 8's before and was skeptical but they actually get real low and have pretty good output. I feel like theyre a little under powered by my cab 1600 so I am thinking about going with something with a little more. They wont knock my mirror off but they will definitely vibrate my cellphone across my center console without issue.
Hmmm learn something new everyday lol. My sa12s I had to keep the mirror down, it wouldn’t stay up for ****, it got aggravating putting it up every beat first time I gave the system a go. Csctang designed the box. I knew it’d be loud but **** not that loud, before I say I have sa12s they ask if I have 15’s. That Orion 2500 is the TRUTH, check out big d dyno it on YouTube.
433
Bonjour et bienvenue à mon ami d'outre-Atlantique! Need a lot more info on what the goal is and what you are working with. What car? Did it come...
Ya man.. No telling how long that will last. you do one are and the weakest point begins to fail sooner or later. Looking at CDT speakers,. They...
I replied to your other thread. Id look at Infinity Kappas for the money on 6x9 components and an amp. But I would have chosen the kenwood over...
To find out what fits, head over to Crutchfield.com. For actual purchase you may want to try CDT.com. They seem to have an everlasting sale. Good...
SLAB153
SLAB153
Lafayette, LA
inteva6184
    May 31, 2024
    May 24, 2024
