2017 F-150 Crewcab options
Is there any foam under the carpet that might compress with the seat down?.. I was told it fit well... it was 11" in front, 8" in back 56" wide...
I raked the baffle slightly so it would fit under the seat lip better... magnet clears and it goes low and loud according to him... he had a CAB at 1/2 ohm on it so I ported it for +2000 watts
With 2” lift I can do the 11” front, 8” back, I don’t mind the 56” it’ll stick out a inch on each end.
I would suggest you do yourself a favor and buy the kit. It's not just square tubing or a straight up lift like suggested. I asked him to post pictures of it finished and he never did I like to see what he came up with. Here's a picture of the front mount for the lift kit and a picture of the box I did with a lift I used sa-8 v3s.http://i1259.photobucket.com/albums/ii542/inteva61841/20171231_124158_zpskkqbraxg.jpg
http://i1259.photobucket.com/albums/ii542/inteva61841/20171231_124209_zpsqeb61xcc.jpg
Check inbox
Ok cuz the video by Lmi welding rear lift kit is on YouTube installing it.
Yeah its a really easy kit to install. I like mine I would absolutely spend the money to buy the kit again.
Ah, I weld so I can get it done I mean the bottom pieces easy as hell to get. The rear upper hook with spring not too bad. I saw 2 z shaped brackets but video didn’t show where it go, what’s up with the z brackets?
Thats the picture in the link I sent you. Its the front mount. None of its crazy difficult to do it just wasn't worth it to me to spend the time figuring it out.
Ah I gotcha. So you went with the Sa8’s? Never heard of 8’s well the bs kicker factory 8” on 200 watt amp in the truck now. Been around 12’s n 15’s my whole life. Heard 10’s once or twice not bad.
Yeah the forum talked me into them. I had never heard 8's before and was skeptical but they actually get real low and have pretty good output. I feel like theyre a little under powered by my cab 1600 so I am thinking about going with something with a little more. They wont knock my mirror off but they will definitely vibrate my cellphone across my center console without issue.
Hmmm learn something new everyday lol. My sa12s I had to keep the mirror down, it wouldn’t stay up for ****, it got aggravating putting it up every beat first time I gave the system a go. Csctang designed the box. I knew it’d be loud but **** not that loud, before I say I have sa12s they ask if I have 15’s. That Orion 2500 is the TRUTH, check out big d dyno it on YouTube.
SLAB153
SLAB153
Lafayette, LA
inteva6184
